What is Power Saving Schedule?
Power Saving Schedule lets you automatically reduce your network's power consumption during specific times. This helps you reduce your carbon footprint and energy costs while you maintain full control over your network's performance.
Power Saving Schedule is an optional feature that temporarily lowers your network's performance to save energy. It's perfect for times when you're not actively using your network, like overnight or during work hours when your home is empty.
You can set custom schedules that fit your lifestyle. Power Saving Schedule won't turn on automatically—you'll need to enable it first. Once it's set up, it's designed to work quietly in the background.
What are the Key features?
While Power Saving Schedule is running, your network will use less power. Primary network functions still work, but peak performance is reduced. Make sure you don't need optimal performance during your scheduled power-saving times.
Power saving schedules
Choose specific days and times when you want to save energy. You can create multiple schedules that run at different times throughout the day.
Adaptive Ethernet
This feature adjusts Ethernet link speeds to reduce power consumption.
Automatic downrated Ethernet performance Wi-Fi 7 eeros (eero 7, Max 7, Outdoor 7, PoE 7, Pro 7) to 1 Gb
See more information about Adaptive Ethernet: What is Adaptive Ethernet Mode?
Additional Performance Adjustments
Wifi radios adjust to 1x1 spatial stream, reducing optimal performance while maintaining connectivity
CPU performance reduction on certain eero models
Visual indicators
You'll see when Power Saving Schedule is active in the app so you always know your network's status.
The LED will turn green whenever an eero is in Power Saving Schedule mode.
Energy usage tracking
Check how much power you're saving through the eero app.
Please note that enabling Power Saving Schedule will temporarily disable wireless connectivity on your network for up to 5 seconds.
How do I set up Power Saving Schedule?
Open the eero app and go to Settings > Advanced networking.
Scroll to the Network services section and select Eco efficiency.
Toggle Adaptive Ethernet on to enable power saving.
Toggle Power saving schedule “on” to set when Power Saving Schedule should automatically activate.
Select Add schedule to create a custom schedule, or choose from pre-set times.
When setting a custom schedule, enter a name for your schedule and select at least one day.
Tap Save to activate your schedule.
You can create multiple schedules that run at different times. For example, you might set one schedule for overnight and another for weekday work hours.
What is the best way to use Power Saving Schedule?
Plan around your usage: Set schedules for times when you're not streaming, gaming, or doing other activities that need high performance.
Start with one schedule: Try a single overnight schedule first to see how it works for you. You can always add more schedules later.
Verify status in the app: Use the eero app to quickly verify that Power Saving Schedule is active on your network. The app will display a green “leaf” icon at the top of the home screen whenever power saving is enabled.
Frequently Asked Questions
Get the support you need
