What eero power adapters and Ethernet cables are available?
eero offers replacement and additional USB-C power adapters and Ethernet cables for purchase on Amazon.com (U.S. only).
What power adapters does eero offer?
eero offers five USB-C and PoE+ power adapters with different wattage levels. We recommend using eero-certified power adapters for reliable performance.
Note: Purchasing a power adapter with higher wattage won't increase the range of wifi coverage.
Power Adapter Specifications
15W USB-C power adapter
- Plug type: Type A
- Compatible devices: eero, eero 6, eero 6+, eero PoE 6, eero 7
- Input voltage: 100–240V~0.45A, 50/60Hz
- Output voltage: 5.0V⎓3.0A, 15.0W
27W USB-C power adapter
- Plug type: Type A
- Compatible devices: eero, eero 6, eero 6+, eero Pro, eero Pro 6, eero Pro 6E, eero PoE 6, eero 7, eero Pro 7
- Input voltage: 100–240V~0.65A, 50/60Hz
- Output voltage: 5.0V⎓3.0A, 15.0W; 9.0V⎓3.0A, 27.0W
45W USB-C power adapter
- Plug type: Type A
- Compatible devices: eero, eero 6, eero 6+, eero Pro, eero Pro 6, eero Pro 6E, eero PoE 6, eero PoE Gateway*, eero 7, eero Pro 7, eero Max 7
- Input voltage: 100–240V~1.20A, 50/60Hz
- Output voltage: 5.0V⎓3.0A, 15.0W; 9.0V⎓3.0A, 27.0W; 15.0V⎓3.0A, 45.0W
140W USB-C power adapter
- Plug type: Type B
- Compatible devices: eero, eero 6, eero 6+, eero Pro, eero Pro 6, eero Pro 6E, eero PoE 6, eero PoE Gateway, eero 7, eero Pro 7, eero Max 7
- Input voltage: 100–240V~2.5A, 50/60Hz
- Output voltage: 5.0V⎓3.0A, 15.0W; 9.0V⎓3.0A, 27.0W; 15.0V⎓3.0A, 45.0W; 20.0V⎓5.0A, 100.0W; 28.0V⎓5.0A, 140.0W
30W Outdoor PoE+ power adapter
- Plug type: Type B
- Compatible devices: eero Outdoor 7
- Output voltage: 56V, nominal 48V system
*When used as a non-POE switch.
Power adapters for your Ring Alarm Pro can be requested by contacting Ring.
What Ethernet cables does eero offer?
eero offers Cat5e and Cat6a Ethernet cables in multiple colors and lengths on Amazon.com (U.S. only). Most eero wifi systems include an Ethernet cable, but you can purchase additional cables as needed. All cables are available for purchase in 1-packs and 5-packs.
Cable Specifications
Cat5e Ethernet cable
Colors: White
Available lengths: 3 ft (0.91 m)
Material: Elastomer
Throughput: Supports speeds up to 1 Gbps
Click here to purchase on Amazon
Colors: Arctic White, Titanium Black, Midnight Blue
Available lengths: 6 in (0.15 m), 1 ft (0.30 m), 3 ft (0.91 m), 5 ft (1.52 m), 10 ft (3.05 m)
Material: Double-braided nylon
Throughput: Supports 10 gigabit+ speeds
eero Cat6a and Cat5e Ethernet cables work with all eero devices. They're also compatible with laptop and desktop computers, gaming consoles, smart TVs, security cameras, printers, adapters, servers, modems, and switches.
Recommended product pairing
Cat5e cables: Work with all eero devices, support speeds up to 1 Gbps
Cat6a cables: Work with all eero devices, support 10 gigabit+ speeds (recommended for eero PoE Gateway and eero Max 7)
Get the support you need
