What is eero Business?
eero Business is a subscription that simplifies managing your business wifi network. It's built for businesses with up to 100 connected devices, up to 50 employees, and up to 7,500 sq. ft. of space.
eero Business works with most Wi-Fi 6 and Wi-Fi 7 eero devices. It's available as a subscription you can purchase right within the eero App. New subscribers can try the service free for one full month.
eero Business features:
  • Multi-SSID
  • Captive Portal
  • Bandwidth Limit
  • VIP Support
  • Hotspot Backup
  • Advanced Security
  • Smart Home Hub
  • Historical Data
  • Ad Blocking
  • Content Filters
  • Block Apps
eero Business costs $299.99 per year (auto-renews until canceled). To subscribe, open the eero App, tap Home, then tap eero Business.
Note: Subscriptions purchased in the eero App don't apply to networks installed by a Pro Installer or Internet Service Provider (ISP).
Which models is eero Business compatible with?
  • eero 6 (router)*
  • eero 6+
  • eero Pro 6
  • eero Pro 6E
  • eero PoE 6
  • eero PoE Gateway
  • eero 7
  • eero Pro 7
  • eero Max 7
  • eero Outdoor 7
  • eero PoE 7
If your business wifi network includes incompatible devices, check out our Wi-Fi 6 and Wi-Fi 7 options on eero.com/shop.
Bandwidth Limit isn't an available eero Business feature on networks that include an eero Max 7 or a Point-to-Point Protocol over Ethernet (PPPoE) network as determined by your internet service provider. All other eero Business features (such as Multi-SSID, Captive Portal, and Hotspot Backup) will still be available.
*The eero 6 Extender is not compatible with eero Business.
How do I sign up?
Before signing up, make sure:
To sign up:
  1. Open the eero App
  2. Tap Home
  3. Tap eero Business
  4. Tap Subscribe
  5. Follow the on-screen instructions to purchase through your device's payment processor (payment is processed through the App Store for iOS and the Google Play for Android)
  6. Verify your subscription in the eero Business section under Home
What happens when I complete the purchase of eero Business?
Once you complete your purchase:
  • eero Business activates on the network you chose at sign up
  • Advanced Security turns on automatically
  • An open, passwordless guest SSID with Captive Portal is created
You can configure Captive Portal and add any additional SSIDs needed for business critical devices, IoT devices, or POS systems. You can add a customized business splash page for customers.
How do I manage my eero Business subscription?
Your subscription continues until canceled. If you don't wish to continue auto-renewing, you must cancel your subscription at least 24 hours before the next billing period begins.
To make changes to your subscription:
Your 30-day free access will automatically convert into an Annual plan, which will auto-renew until you cancel. Full information can be found in the eero Subscription Terms of Service.
What happens if I cancel my eero Business subscription?
Once your billing period ends, your eero Business subscription expires. You'll lose access to all eero Business subscription features.
If you have a "Business" or "IoT" SSID, those SSIDs will no longer be active. If you have an active guest network, that will stay active but will no longer have a captive portal. If you have any port forwarding or IP reservations on the guest, "Business", or "IoT" SSIDs, those will no longer be active. Devices connected to the guest, "Business", or "IoT" SSIDs may be connected automatically to the main network based on their configuration.
What happens to my eero Business subscription if I transfer my network to someone else?
If you transfer your network to another owner, this network will no longer be associated with your eero Business subscription. The new owner will be responsible for purchasing their own eero Business subscription if they want to continue using the features.
If they don't purchase eero Business, this network will lose access to all eero Business subscription features. Any "Business" or "IoT" SSIDs will no longer be active. Any active guest networks will stay active but will no longer have a captive portal. Any port forwarding or IP reservations on the guest, "Business", or "IoT" SSIDs will no longer be active. Devices connected to the guest, "Business", or "IoT" SSIDs may be connected automatically to the main network based on their configuration.
What should I do if I have an incompatible eero device model connected to my network?
If you have an incompatible eero device (such as eero 6 Extender or eero Gen 1), you'll be unable to subscribe to eero Business. To resolve this issue, you can either replace the devices with a compatible eero device model, or remove the incompatible device models.
To remove an incompatible device:
  1. Open the eero App Home tab
  2. Select the incompatible eero device
  3. Tap the  (more options icon) in the top-right corner
  4. Tap Remove "name" eero
  5. Tap Remove from Network at the bottom of the screen
 Note: If you delete your gateway eero, your network will go offline.
How do I upload my own custom logo and terms of use for a captive portal from my desktop or laptop?
  1. Log into insight.eero.com with the email address or Amazon account associated with your eero account
  2. Click the name of the network you’d like to work on
  3. Click Settings on the left
  4. Click Network settings
  5. Click Edit next to Captive portal
  6. Click the Click to upload button, and select the file containing your logo
    • Click the (laptop icon), (tablet icon), or (smartphone icon) to preview your captive portal on different devices
  7. Click the Save button in the bottom-right corner when you’re done
Custom terms of use:
  6. Under Business Terms of Use, click the Upload custom Terms of Use checkbox
  7. Click the Click to upload button, and select the file containing your terms of use
  8. Click the Save button in the bottom-right corner
How do I upload my own custom logo for a captive portal from the app?
  1. Tap the Settings tab in the bottom-right corner
    • If you have multiple business networks, select the one you wish to work with
  2. Tap Multi SSID
  3. Tap your guest wifi name
  4. Ensure Enable guest wifi network and Enable captive portal are toggled on
  5. Tap the Edit captive portal
  6. Tap Captive portal logo
  7. Tap Upload logo to upload a logo that will be displayed to your visitors on your captive portal. Your logo should be 200x200px minimum resolution, a PNG, JPG, or JPEG file, and 5MB maximum. We recommenced uploading an image with no margins and a transparent background to allow you to easily switch between light and dark mode
  8. You have the option to choose a file or select an image from your Photo Library
  9. Browse your Files or Photo Library and select the logo you would like to utilize within our captive portal
  10. Once your logo has been uploaded, you can Remove, Replace, or View the file
If you receive one of the below error messages upon upload of your captive portal logo, check the reason for the upload failure and attempt to upload the logo again:
  • Unable to upload a logo.
  • File dimension too small. Please select a file with a resolution of at least 200x200px.
  • File too large. Please select a file below 5 MB.
How do I upload custom terms of use in the app?
  2. Ensure Enable wifi network and Enable captive portal are toggled on
  3. Tap Edit captive portal
  4. Tap Custom terms of use
  5. You can use the text editor to type your terms of use, or you can import them as a file. Tap Import terms of use from file to import a file from your device’s library. Please note that only .txt files are supported at this time
  6. Tap Save in the top-right corner
If I need to have my eero devices in bridge mode or custom DHCP, can I use eero Business?
In order to take full advantage of eero Business features, only Automatic or Manual (DHCP) mode is supported.
How do I convert my eero Plus plan to an eero Business subscription?
eero Plus subscribers who want to subscribe to eero Business can do so by canceling their eero Plus subscription and waiting until their subscription term ends before subscribing to eero Business. If you want to start using eero Business as soon as possible, you have a few other options:
  • New account setup - If you're setting up a business wifi network separate from your home network, we recommend registering that network with a new email address not attached to an eero Plus account.
  • eero Plus subscription cancellation - If you have eero Plus already set up on your business network, you'll need to cancel your eero Plus subscription via the method in which you signed up for the service (this may either be through the App Store or Google Play Store, or through account.eero.com). Once cancelled, you’ll need to contact your point of purchase to have the subscription removed completely.
What’s the difference between eero Plus and eero Business?
An eero Business subscription reduces the complexity of managing your business wifi network with features like Multi-SSID, Captive Portal, Bandwidth Limit, Hotspot Backup, Advanced Security, Historical Data and more.
Included on all eero networks (no subscription required):
  • Wifi scheduling
  • Multi-Admin
  • Smart Home Hub
Both eero Plus and eero Business include:
  • Historical Data
  • Hotspot Backup
  • Ad blocking
  • Advanced Security
  • Content Filters
  • Block & Allow Sites
  • Block Apps
  • VIP Support
What does eero Plus offer that eero Business doesn't?
  • DDNS
  • VPN powered by Guardian
  • Malwarebytes
  • 1Password
What does eero Business offer that eero Plus doesn't?
  • Multi-SSID
  • Captive Portal
  • Bandwidth Limit
Get the support you need
