How many eeros do I need?
Every home is unique, and eero was designed to be flexible so that it can be a fit for any home. We recommend the number of eeros you need based on the size of your space, number of users, and your internet speed plan. You can find your eero system by selecting the Find your eero feature on the eero website or by contacting Support.
What factors affect how many eeros I need?
Consider your home's layout when determining how many eeros you need:
Length, number of rooms, and floors
Interference-inducing obstacles like brick walls and large appliances
Other electronics with Bluetooth or wifi radios
Where should I place my eeros?
For detailed placement guidance, see our dedicated article: Where should I place my eeros?
Do I need to add more eeros to my network?
You can use the Coverage Scan feature to test out various ways of placing your eeros to maximize your coverage. Since every home is different, you can always add an additional eero where needed.
Get the support you need
