What is Block & Allow Sites?
Block & Allow Sites is an eero Plus feature that lets you manually block or allow specific websites and domains. You can apply settings to your entire network or to individual Profiles.
Note: Content Filters block broad categories. Block & Allow Sites gives you control over individual domains.
How do I block or allow a site?
You have two options: apply settings to your entire network, or customize them for a specific Profile.
For your entire network
On the eero App Home tab, tap Security & privacy to see a list of eero Plus features
Tap the list to open the eero Plus page
Tap Network controls
Tap Block & Allow Sites
Tap Add Blocked Site to add a blocked domain, or switch to Allowed, and tap Add Allowed Site to add an allowed domain
Type in the desired site or domain under Domain
Tap the Network toggle button so the domain is blocked/allowed on your entire eero network
Once you're ready, tap Save
For a Profile
On the eero App Home tab, tap the Profile you want to block/allow a domain for
How do I delete a site from the Block & Allow Sites list?
You can delete sites from your entire network or from a specific Profile.
Tap the desired domain in the Blocked or Allowed list
Tap Delete Site
On the pop-up "Are you sure you want to delete this site?" tap Delete Site again to confirm
For a Profile
On the eero App Home tab, tap the Profile you want to update
Tap Delete Site
How do domains work in Block & Allow Sites?
Domains are based on their Fully-Qualified Domain Name (FQDN). You can manage domains at any level of the hierarchy.
Note: Allowed Sites always take priority over Content Filters and Blocked Sites.
Domain Examples
example.com — Affects the entire domain
subdomain.example.com — Affects only that subdomain
org — Affects all .org domains
Common Mistakes
www.example.com
Enter example.com instead. "www." only blocks that subdomain.
https://example.com
Enter example.com instead. URLs aren't accepted — use FQDNs.
example.com/page
Enter example.com instead. Pages are removed automatically.
*.org
Enter org instead. Just enter the TLD name.
Frequently Asked Questions
Get the support you need
