Low Power Standby and WiFi Off Modes
eero supports two special modes that reduce power consumption or disable wireless connectivity while keeping your device operational.
How do I enable WiFi Off mode?
WiFi Off mode temporarily disables wifi on your eero but keeps wired Ethernet active.
To enable WiFi Off mode:
Once your eero is set up, tap the reset button 8 times
Your eero will reboot, indicated by a flashing white LED
Your eero is now in WiFi Off mode
To return to normal wifi mode, tap the reset button once, or unplug your eero from power.
How do I enable low power standby mode?
Low power standby mode reduces power consumption while keeping your eero ready to activate.
To enable low power standby mode:
Once your eero is set up, tap the reset button 10 times
Your eero will immediately enter low power standby mode and the LED will turn off
Your eero is now in low power standby mode
To return to normal wifi mode, unplug your eero from power, then plug it back in.
Get the support you need
