How do I manage the eero LED light?
With the eero App, you can change the brightness or turn off the LED of any online eero you want. To manage your eero’s LED:
Open the eero App
On the Home tab, tap the name of the eero whose LED you’d like to manage
Tap Status light
Move the slider left or right to change the brightness, or tap the blue toggle button to turn off the eero’s LED
Tap the < (left arrow) or the Back button in the top-left corner to save
Note: Your eero must be online and its LED color must be solid white before you can turn it off or change its brightness. The LED will turn back on at full brightness while the eero is offline, rebooting, or resetting. To learn what the different LED colors mean, see What do the colors of the LED light on my eero mean?
Get the support you need
