What do the colors of the LED light on my eero mean?
On the front of your eero, there is a LED status light. When everything is running correctly, your eero's light will be solid white (unless you have turned it off). If your LED is in a different state, including a different color or is blinking/flashing, please refer to the list below:
LED Status Color
LED Behavior | State |
| No power or LED disabled |
| Online |
| Connecting |
| Ready for setup |
| Bluetooth pairing |
| Using Hotspot Internet |
| Identifying Zigbee devices |
| Power saving |
| Multiple eero devices identified |
| Power supply problem |
| Offline |
| Resetting |
Note: The meaning of the colors used by eero Signal’s LED differ from the table above. See eero Signal Setup guide for more information.
Get the support you need
