How do I connect a device that can't detect my eero 6 or eero Pro 6 network?
If your device can't detect your eero 6 or eero Pro 6 network, enable Legacy Mode in the eero App. This temporary solution helps devices with older wifi drivers connect to your network.
Why this happens
Some devices with older drivers or software cannot connect to networks with eero 6 or eero Pro 6. This commonly affects devices with certain Intel wireless adapters that support 802.11ac but have compatibility issues with Wi-Fi 6 (802.11ax) routers. See Systems Using Intel® Wireless Adapters Supporting 802.11ac Not Displaying Wi-Fi 6 (802.11ax) Networks in Scan List of Available Networks
Though your Wi-Fi 6 network is running, affected devices won't detect or join the network. Update your device's drivers to resolve this permanently.
How to enable Legacy Mode
Support tab
Open the eero app, and tap the Support tab
Tap Connect devices that can't detect Wi-Fi 6
Settings tab
Open the eero app, and tap the Settings tab
Tap Troubleshooting
Your device should now detect and join your eero network.
Note: Legacy Mode may reduce network speeds. After updating your device's drivers, turn off Legacy Mode to restore full performance.
Get the support you need
