Why does my eero app say "Unable to add eero"?
This message appears when you try to set up a network using an eero model that doesn't have Ethernet ports. eero models without Ethernet ports can't be used as a gateway eero to create a network — they can only extend an existing one.
What do I do if my eero app says "Unable to add eero"?
To set up a new eero network, you need an eero model with an Ethernet port. Your gateway eero must connect to your modem or router through Ethernet.
Which eero models can't be used as a gateway eero?
The following models don't have Ethernet ports and can only be used as wireless extenders:
eero Beacon
eero 6 Extender
Echo devices with eero Built-in
What can I do with my current eero?
Once your network is set up with a supported gateway eero, you can add this eero as a wireless extender to help cover wifi dead spots. Extender eeros don't need Ethernet ports — they connect over wifi. For steps, see How do I add or remove eeros from my network?
Get the support you need
